Hub and sprocket
Dugger
I'm working on a case 660
I need hub and sprocket behind big pulley
On beater shaft
Part no. F. 83088
Need help finding one
Thanks
Doug
Unless it has to fit a real special tapered or splined shaft, it should be easy to find a Weldasproket and an appropriate hub.
Even if a little machining is needed, it should be doable.
(reply to post at 23:56:21 02/19/16)
Oh it's doable
I got it off and I think I can save it
I think I will get one made to match also
I will try to post a pic so all those will believe
What I got
