I need to load a Gleaner K2 with a seized engine on my gooseneck. Any tips or suggestions? I have already moved the heads and just have to get the combine. I am planning on unhooking the trailer and running a chain through the neck to the combine to pull it up with a tractor (block the tires on the trailer). I know it will take a couple of spotters as well as the drivers. Then the plan is to let the air out of the tires to reduce the height. It looks like a K2 is about 129" according to the net (currently right at legal limit by my calculations when you add trailer height).
Any tips/tricks or recommendations?
Thanks
Thanks
