elevatorman724
Finally got back to fixing brakes on combine thought I'd post what had to do in case some one else going through same problem. Got wheel cylinder kits from Napa ray bestow 3 dollars apiece. Master cylinder from tr 97 combine they're the same 20 $. Bench bled used master cylinder. Put it on and bled lines. Couldn't get good pedal on right. Put hose from wheel cylinder bleeder to master cylinder reservoir primed hose whith oil squirt bottle full of brake pedal bled right side again got pedal then. Pedals uneven though so adjusted pedal linkage to even out. All good then then got emergency brake cables from Jd chopper. I know most everybody just uses hydro to stop but we wanted brakes to work because in Hy traffic area
