One of the ground drive belts (upper) seems excessively loose so going to try and change it out. Got both belts in today, as was told should change both together (thanks Mike). Question is how big of a job is it? Looks like I have to take the hyd. pump off the end of the shaft and the support bracket to get the belt around the top sheave? And how to get the belts in the center variable sheave? Any tips or tricks would be appreciated.
Last week we had went through the adjustments for these belts in the manual. Didn't really take much to get proportioned per the manual - adjusted the hydrolic cylinder for clearance on sheave halves was all that was needed. Can pull top belt 3-4 inches very easy with the lower belt only moving about 1/2 inch with 20 lbs. force as manual wanted.
