Case 660 help needed
dairyman
Just had the rocker shaft that drives the straw rack break off just outside of its bearing how do I remove it so I can weld it? This is an early 660. Also where can I find a replacement as I'm unsure welding it will work that well and the local salvage yards do not have anything for these older cases. Thanks Dave.
I put a used one I my 600 when I farmed lasted 2 seasons and broke again. Not fun putting them in by yourself either!
I took the broken shaft to a machine shop and had them make one. Worked great as far as I know it's still going.
