Replacing Belt On JD 6620 Rotary Screen
2underage
Good day to all. The belt on My JD 6620 rotary screen is broken and I need help on finding instructions on replacing it. The guard brace is keeping me from putting the bet on the pulley. I am not sure of what I need to do to put the new belt on. Have you replaced one of these and how did you do it. This is the screen in front of the radiator. Thanks.
just did my 7720 this afternoon, had one of the pulleys on the tightner go out and frayed the belt , took the bolt out in the very center that holds everything together and push it out and you will have room to slide the belt in between took all of 5 minutes after I figured that out
