Gleanerk2
My gleaner k2 blew the variable speed shieve apart were the hydraulic hose hooks on to its like it just unscrewed and fell off so I screwed it back on and now it clatters did I lose something that was in thier all thats thier now is a o ring on the pulley! And you can look in the piece that unscrewed and see alittle snap ring and the hole the oil comes through frome the 90 degree fitting! Any thoughts?
I can't remember those details any more. I would have to look at a parts diagram, just like I imagine you will have to, to see what should be there.
(quoted from post at 15:49:56 10/22/15) My gleaner k2 blew the variable speed shieve apart were the hydraulic hose hooks on to its like it just unscrewed and fell off so I screwed it back on and now it clatters did I lose something that was in thier all thats thier now is a o ring on the pulley! And you can look in the piece that unscrewed and see alittle snap ring and the hole the oil comes through frome the 90 degree fitting! Any thoughts?
The bearing that takes the brunt of the side thrust is likely shot.
I have blown the o ring on my G. and the bearing would fail.
