notjustair
Two years ago I had JD put a new bottom seal on the wobble box on the 922. Last year when the knuckle needed replacing at the end of the sickle bar I discovered it was leaking again. I had them come back out and get it (they could hardly get the arm off the bottom). Randy called back - the shaft is grooved. I asked about a speedy sleeve but no one on the shop was keen on it because of its size. Seems to me we should have mentioned the grooved shaft before, but that's gone and passed.
So $1200 (or $1700, I can't remember) later they installed a shiny new wobble box. It has about 500 acres in it and the new one is weeping. Not dripping, but it has itself and the arm coated in chaff. Do those things just ooze or do I get on the phone?
