Case IH final drive repair
Czar800
New User
Final drives on my case international 1660 combine started leaking oil. I'm in the process of rebuilding them and need advice on The outer bearing. I understand the inter bearing Is a pressed on. So my question is the outer bearing is it a pressfit also. The outer bearing is a 749S the inner bearing is at 39590 both Timken bearings. I understand you set the drag to 25 foot-pounds my problem is the inner bearing 39590 will not slide over the shaft.
(quoted from post at 10:25:38 10/01/15) Final drives on my case international 1660 combine started leaking oil. I'm in the process of rebuilding them and need advice on The outer bearing. I understand the inter bearing Is a pressed on. So my question is the outer bearing is it a pressfit also. The outer bearing is a 749S the inner bearing is at 39590 both Timken bearings. I understand you set the drag to 25 foot-pounds my problem is the inner bearing 39590 will not slide over the shaft.
