super99
I have a 6600 Hydro with a 329 motor, old style 444 head that the stalk rolls are getting wore, so a lot of stalks go thru the combine. I started corn with the concave set on 17 and cylinder set at 600 rpm. It seemed to be doing a good job, getting the corn off of the cob and a really clean sample. Quite a bit of corn going thru the return. When I unloaded the first wagon, there was a lots of cracked corn in it. The cobs are broken cross ways, not length wise. Some of the cobs have 1/3 to 1/2 of the kernel still on the cob. I slowed the cylinder down to 500 and then there was lots of corn left on the cob. I speeded up to 550 and still corn on cob. Set it back to 600 and closed cylinder, I'm down to 14 and still getting corn on the cob and cracked corn. Cobs are broken, not split. Corn is testing 12 to 15%, yields vary from about 20 on the sandy spots to 180+ on the good ground. Running in 3rd gear about 3 on the hydro. Where do I go next? I thought you opened the concaves and started closing then until all the corn came off of the ear. The cracked corn tells me the cylinder is too fast, but when I slow it down it doesn't get all the corn off of the cob. Suggestions?? Thanks, Chris
