rustymn
New User
I need to change the engine drive belt on my f2 gleaner. what is the easiest way to get the traction control belt off and how does the hydraulic hose disconnect from the sheave.
I changed it on my F3 and I don't believe I removed the traction belt. memory is getting abit fuzzy but I think I was able to somehow roll the new engine belt under the traction belt. Get the variable speed as slow as it will go and that should get you a little slop to work with. Hopefully someone else will respond with more details.
yes maybe you can crank the motor and belt into place ,,, had a glener f serverl yrs , belt swapping was fairly simple .,.decent machine,,more moving parts than any combine I know of...if a fella was raised up with one,.and learned all the trix . I think he could do clover seed all day, and fly to the moon at nite ,,. kinda confusin for a massey kid
Hyd hose disconnect? Like any right angle fitting, use two wrenches. Just a small dia hyd hose fitting. I think Doug WI is right about rolling the belt over the other sheave.
I believe I ran the lower belt all the way slow, then I took the big screw bolt out that holds the middle sheaves together, back side of where the hydraulics is? Or did I take the hyd cylinder loose, I forget, but it made the middle sheave real loose and could work the engine belt through real easy.
