gleaner F sieve replacement
I was look at replacing my adjustable air sieve with a #12 triangle to fit the crop I'm harvesting. I took out the rear bolts but can't seem to figure out how to get to the front bolts. only thing I can think of is somehow getting in there and laying down while someone on the outside removes the bolts for the chaffer. once that's out then a guy could get in there you could access the front bolts for the sieve. am I correct on this removal procedure? Seems like a great deal of work. considering the fact I'm going to swap between the #12 triangle and the air sieve I'm going to have to come up with a easier way to swap these in the future. Any suggestions on how to remove this air sieve?
Don't know about the F, but I just pulled the chaffer and sieve out of my F2 and there was a pin, all the way across, for the sieve. Could it be something like that? The F2 parts book is online, maybe the F is also
IIRC just loosen the rod peagrower talks about. Helps to reach underneath from the rear (to the front) with a 2x4 to pop the chaffer up, and loose. Same with re-install- props up the chaffer to get it over the rod.
