Ronald Cummins
New User
this spring i purchased a used vermeer 505 super i baler , i used it to roll approx 40 rolls of hay, the belts were worn and i noticed a bearing making a noise i took it to young farm machenery flemingsburgh ky my closest vermeer dealer , young replaced the belts shaft ,bade bearing ,he then called me and stated that the belts he installed would not track properly and he had then discovered the front crosember was bent or sprung and his part was no longer avaible from vermeer and their was nothing he could do i picked up the baler and gave him a check for 3,000.00 dollars for work he done now my question is this part avaible under a different part number or does anyone know where a used part is avaible or any suggestions what i might do when i took it to mr young i instructed him to go over the baler and fix all needed parts as i was planning on keeping the baler as of right now i am stuck with the cost of the used baler plus 3000 dollars paid to him gentelmen please advise and help if possible thanks ronald germantown ky
