pea_grower
Having trouble with the power steering on an F2 that has the steering motor under the steering wheel. Serial # 47×××. Seems to get stiff, hard to turn.
Am told that the hydraulic pump sends fluid to a flow divider, before the ps or other hydraulics. Anybody had trouble getting material in the flow divider? I did have to replace the hydraulic oil filter a couple of years ago, because hydraulics quit working. Filter solved it.
Was suggested to check the oil pressure, I'm assuming right of the valve body. Any other suggestions?
