perkins 354 losing oil pressure after sitting
my perkins in my 510 seems to loose oil prime when it sets. takes 30 seconds or so for it to come up on the gauge once started. would this be in the pump or regulator?
Have you tried a different gauge?- Like a simple old fashioned mechanical gauge you could fasten right to the engine, for observation while someone else starts it up?
That would get my attention too. I assume it's naturally aspirated. The only change I've heard in engine start up noise is when a turbo gets oil.
naturally aspirated. holds good pressure when running, just on start up, like it's draining all the say back to sump. was not sure if regulator helped keep it from doing that.
