105 john deere combine parts anyone need parts???
i have a 105 john i got it for the feeder house and head there are pulleys and belts, sprockets, no motor, sieves, idk if you need somthing let me know the parts are guna be dirt cheap just pay me a little for taking off what you need and shipping. drive tires are in good shape.
Loren
Did it have a diesel motor? I need the pipe between the intake manifold and the air cleaner. I am also looking for a good straw chopper. Where are you located? I also need a deep tooth sieve for shelled corn. Thanks Tom
i am located in northeastern south dakota 70 miles north of watertown south dakota. it did have a diesel motor gone before i got it i can text pics of things or call me at 605-467-0974 anytime. i only wanted head and feeder throat everything else is up for grabs. the lift cylinder has springs and stuff i wont need any of that good cab all glass is there straw chopper seems good. give me a call. thanks Loren
Are the two outside drive axles with sliding couplers available. My left drive shaft and coupler stripped the splines. Thank You.
(quoted from post at 08:35:53 09/16/15) Are the two outside drive axles with sliding couplers available. My left drive shaft and coupler stripped the splines. Thank You.
brake juice axles and couplers are in good shape got your voice message i am unable to call canada with my fone try me a couple times in a row should get me then or email me [email protected]
