1660 CIH grease
mudcreek183
We just this combine and start to do some work on it for fall.On the grease chart it said on the rotor driven pulley to only use case 251 H EP grease I have always used a good grease on my equipment is there a reason that I have to use this grease on that fitting? The book says that grease or equivalent on the other fittings.
I've always used good quality grease. The first year I had the 9500 the walker bearings went out.
Twice. The field mechanic asked what grease I was using so I showd him. He said NEVER run
anything but Deere gun grease. I switched and never had another one go out. That was about
2500 hours ago.
It isn't going to be cheap. Buy a new grease gun and a box of that grease. Use it only on that
combine. Or, you could just switch to the good stuff. I have to mortgage the farm to buy a case but
there's never a question about what grease I use. I think that stuff is like $10 a cartridge or some
stupid amount. I just pay the bill when it shows up.
I would be using what the grease chart and manual calls for. If you ever have to change a rotor bearing because of using the wrong grease you'll wish you had.
We use Mystic JT-6. Just need a extreme pressure grease use it on the whole machine. Has worked on 2 old axial flows since 1987.
I was told by a CIH mechanic the reason for the spec. is due to the material the grease seal is made from.
I mounted a grease gun holder up there under the hood for a gun with the CIH grease in it. Then I don't have to drag two guns up the stairs every
day.
right or wrong i use the same grease on the combine, it is a good high grade grease but i also make sure it gets greased everyday and make sure i see new coming out, this is on a 1680.
