7720 flex head
Yes it will. Don't know how you are set up but could make the rear a little light. Biggest thing to remember is nice and easy on your boundaries laying out the field. Then if the beans are a little damp or tough you can always hang over and not cut a full 25. If you can find one and it's in the budget get a full finger auger they feed so much nicer and don't have beans balling up in the auger then going into the feeder house in a huge wad. Don't waste your time and money on those little cones that attach with self tapping screws. They are a huge disappointment
If it is light in back, you can get what they call T bar weights, there 62 lbs a Piece, they go in between the two steering frame rails. Check your operators manual
