1460 brakes
That's a common problem on the 14 series. There's been a number of threads on New Ag Talk about the problem, incl. this one:
http://talk.newagtalk.com/forums/thread-view.asp?tid=507093&posts=3&highlight=1460 brakes&highlightmode=1#M4122036
If you go to the search page on NAT and type in 1460 brakes you'll get a list of threads that address the problem.
On my 1440 there are bleeder valves by the brakes on each wheel. Even when working good those brakes are nothing to brag about.
The brakes bleed easier when you pressure bleed them from the bottom up.
Almost all the brake fluid loss can be fixed by putting cup expanders in the slave cylinders to keep those bottom cups expanded that cap the bottom of the slave cylinders.
Most any brake parts shop can match them up for you.
