wanted J.I CASE combine heads
I have recently purchased a J.I. CASE 1660 combine with a pickup head it has a dakota pickup on it and i got the original CASE pickup which i dont think i will need if somone is interested. Anyways i am looking for a 14-20 foot straight cut head and a 4 row 30 inch corn head. Looking CASE heads last restort swich over for a different head.
Thank you, Loren
Got a Case 404A corn head and some 16' straight heads here.
Case corn head wasn't the best head. Lots of gear cases and chains.
Been using JD heads for 35 years on 1660's and 1665. E SD
What do i need to put a jd 222 head on my CASE? And what would you want for the CASE corn head and a 16 head? I want the originals more for show little use but am interested in a setup like you have seen some of your photos on here.
The 404 Case corn head has had some parts robbed off it. Some parts on a 404 work on the Case 306 corn head. I use the 6 row 30" 306 head on
a 1665. Need a quik-tach feeder house from a 105 JD to modify to the 1660. Need bigger cylinders to be able to lift the 222 JD flex. I use a
643 JD corn head and it is lighter than my 220 flex. The original lift cylinders will lift the 643 head. Need rear weights on the 1660 if
using the bean heads. A weak point is the pins on the combine for the lift cylinders. They are welded into the frame and only supported on
one side and sometimes shear off.
How much would you want for a 16 foot grain head. I would like to cut some wheat with it this year so sooner i could get it the better.
Thanks Loren
