new Holland square baler feeder tines
I have a 276 small square baler. Had some chain breaking issue, now my feeder tines are damaged pretty bad. They are the metal bracket with the round aluminum shafts. Been trying to find some, all I see is the style that bolts back to back and taper down. And none for my model. Will the ones for a 283 or 500 fit and work!? Thanks
I got a feeling those are a common diameter aluminum shaft.
Go to a local metal supplier and have him cut you some.
Gary
http://www.messicks.com/nh/1174007
this should get you to the tines, under "013 tine bar and cam track". part no for the straight tine is 165030.
Are you talking about the raking teeth that drags the material into the bale chamber area, yeah there going to be expensive if you get them from New Holland, take the stub out and measure it with a 1/2 in open end wrench, i think that/s what they are, @ go from there!
Go to the new holland web site or the Messick's.com and figure out the part numbers you need. They are not all alike. Some are straight, some are curved and some of the curved ones are shorter than the others. And this is all on the same baler! Once you get the part numbers, go to bestbalerparts.com, they will have them for about 1/2 of new holland. lots of other parts there also.
Garry
