ji case 1660 help
Need to know height from ground to top of cab or highest point and width from inside to inside of front tires and outside to outside of front tires thanksin advance
(quoted from post at 21:42:34 06/09/15) Need to know height from ground to top of cab or highest point and width from inside to inside of front tires and outside to outside of front tires thanksin advance
It takes a lowboy or detach to haul a 1660
Dealers use to have a plow dolly....2 wheel dolly with a plate that would pivot on the axle. That allowed you to remove the rear tires on a
combine and chain it to the deck. The pivot allowed the dolly to go around a corner and not skid....think semi fifth wheel plate. You could
hook a semi-mount plow to the dolly and go on down the road to deliver it. Haven't seen one in years.....plows are almost obsolete, so no
dollies.
Here are a couple of pictures of a setup on a 1660 used to pull it backwards. I saw this on a combine that was in an auction. I wish I would have taken more pics.
