Tree-Farmer
Where is the valve to bleed brakes?
I bought a JD 4400 combine at a sale, diesel, went to drive it and the brakes don’t work.
I found the resivoir to add brake fluid. It’s in the platform. I removed the material under my feet in the cab, took off the cover, it was out of brake fluid. I added fluid, but the brakes still don’t work. I think I now need to bleed them
Do I do this from the top? Is the valve near the resivior? Can I reach the valve from the top?
Or do I have to get under the platform, somehow?
Thank you,
Thank you,
