Hey guys, have a very weird problem and thought you all might could help. The starter solenoid on my Gleaner K stopped working right(flat wore out), found out at the auto parts store that a rebuilt start and solenoid was $5 more than just a solenoid so I figured a new starter wouldn't hurt so I got it, the starter and solenoid was just like what was on it, same numbers stamped on the starter, hooked everything back up like the old one but now it will only start and run with the key in the cranking position, when you let the key go it dies but runs good while holding it in the cranking position, I tried another solenoid and even put it on the old starter but did the same thing, funny thing is everything worked perfect on the old starter and solenoid (till it went bad), I'm thinking the key switch doesn't like the new starter and solenoid?? The parts guy was stumped as I am
