Re: Claas Dominator 96
Series 140 Serial Number 14000042. I was told that this machine has some rare parts on it. I will attach a few photo's. Just a few of the mods I have done to the machine. Autopilot seems to lose its satellite signal.
Masseypride
This machine was produced approx. 60 machines before the first production in the US. It has the additional hyd tank support as an after-sales enhancement. Not sure why you have disabled one of the pilot valves in the stack. There"s an up solenoid and a down. One of those no longer functions. I"m not sure how it can function this way. My fingerprints are on every blue Dominator 96 above s/n 100.
Hello Claasguy,
The valve modification must have been done prior to selling the combine. The original owner and I have never had it worked on. Someone has welded the valve body closed. I removed these components due the excessive hydraulic leaks out of these components. I had a hydraulic shop repair or rebuild the leaky components. However, now the header engage does not work. I had to adjust the belts so both the header and combine operate when the combine is engaged. I still have one hydraulic leak on the smaller tank to fix. I believe the O-rings between the pump and tank are leaking. It has been difficult to fix all of these hydraulic leaks. I do have questions about the combine. If it would be O.K. I would like to e-mail you a few of the problems that I see with the machine.
Masseypride
