Got her running yesterday. Hope to harvest some oats in about three weeks. Won't idle and has to be about 1/2 choke to run. Cut access door in grain bin. Next to remove carb. Question: Where can I find a carb rebuild kit? NAPA? My 55 is a square back, so I think the engine is a 303??? Thanks for advice. kelly
thanks for the info on the engine. I don't know year of mine, but the carb is quite large, about the size of a Farmall M carb, so I'm guessing it is a 303.
303 engines have the air cleaner on the right side and hydraulic reservoir on the left. 217 engines are just the opposite.
Look on your carb for any numbers or a tag, take it to napa, they should be able to help. If they cant then you will either have to go to your deere dealer or find something on line. If you subscribe to green magazine there might be some info in there also, hope this helps.
