Hart Carter on a JD 105
JK2
I'm still running a Deere 105 with a hart carter floating cutter bar. I've looked all the places that I used to get the rubber bushings for the sickle drive and don't seem to be able to find any. Does anyone know where I might be able to purchase some?
Thanks for any help you can provide.
John Kinsey
The 810 IH head was HC along with the head that fit the F Gleaner (not 100% sure of this though)
I may have a couple of rubber bushings floating around the shop.
I had a HC floating cutter bar conversion on a Deere 100 series head.
I had purchased a new 13 ft sickle back in 1994 and saved the numbers below.
Hart Carter 880083
Case-IH 179761C91
Deutz Allis 71176567
You may be able to do a "where used" search at the dealer to come up with the parts book for the head and then look up the numbers for the bushings.
I think you need 179783C1 Bushing, pitman stabilizer, rubber. Around $12 at Case IH
How close are you to E SD? I have a 100 series JD 22' head with a Love floating cutter bar. Plastic teeth on the reel. Bought a JD 220 flex and don't have a use for the older head.
