510 drive belt
I got my new motor ready for my combine and need to replace the poly v belt. I only have a operators manual and am trying to figure out how to get the big belt off the separator drive/transmission drive to get the poly v belt off.
does one pull trans pulley? any help appreciated
thanks
Gary
It is not to hard the shifting linkage has to be loosen two set screw mine had the linkage is under the cab.Then loosen three bolts on the trany and the bolts on the tightener.Then jack up the trany. Take off the top drive belt then loosen the idler pulley that for the main drive belt you may have to work it over the pulleys.It always took me about a half hour to do it.
