510 massey combine header
looking for a grain header for my 510 I just bought. came with a corn head but I wanna plant some beans this year also. what other heads other than massey will work any ideas?
thanks
Gary
Check with Skorpiks in Tyndall SD. 30 miles west of Yankton. Last I was by there they had oodles of Massey heads.
Personally I wouldn't fool around trying to adapt another make of head unless you cannot find a good M-F head. The M-F heads work very well, the only real minus is the lack of a built in floating bar. They work well as well as any ridged head with an add-on floating bar but it just plain is not the same as a floating head. Other than normal wear and tear items the lone trouble prone area we had was the wobble box. Loosen the belt and grab the pulley, perceptible movement = needs new input shaft bearing & seal and your good for a season or two if you keep the knife in good shape. I believe the later heads had some improvements in the wobble box but that is going from (bad) memory.
