I have a 550 Massey with a 354 Perkins diesel. The fuel injection system keeps losing prime.
When this thing looses prime I have to bleed the entire system including at least 3 injectors just to get it started.
After it starts it runs fine doesn’t miss or smoke.
Come out next day and it may need a complete rebleed to start.
I first thought I had a bad fuel lift pump…Not the problem
I then replaced my fuel line thinking it was collapsing since it was in poor shape…wasn’t it.
I’ve changed fuel filters thinking I might have a slight leak… not it
There is No diesel showing up in the oil nor do I have any leaks that I can find, believe me I’m looking hard everything is dry except where I bleed the system.
I keep thinking there should be a check valve somewhere in the system that is allowing the system to bleed off but there doesn’t seem to be one in the system.
When I bleed the system using the manual lever on the pump I get a good strong flow of fuel and the system bleeds rather quickly except for the injectors which requires turn ver the engine until fuel comes out of the lines.
frankly I’m at a loss any ideas?
