Farmall 656 main hydraulic pump removal
Wondering if anyone has any suggestions on this one. I have everything loosened/removed as per the shop manual, but the cover plate and pump don't seem to want to budge even after a generous dose of persuasion from a big hammer. Any ideas?
There are two alignment dowels that can bind. Carefully insert a chisel and work around the cover.When it moves,work it out with a big screwdriver/small prybar.BTW,the gasket could be stuck as well.
