HELP !! 9400 combine just quit
Just started on the corn and got a hopper full. Got out and did a walk around. Got back in, gave her full throttle and started to back up when it died. It was just like the key was turned off. I am not getting fuel through the injection pump. Replaced fuel and water separator filters. Cleaned the vent tube of fuel tank. I got 12 volts to the fuel shut off solenoid when the key is on. Pulled the solenoid out of the pump and it seems to be working. The only thing I have not tried yet is making sure the injection pump is turning. Is it the injection pump? Any thought or ideas would be appreciated,
Mine did that a year ago. I was idling unloading when my 94 just died. Mine would not even turn over. Lights worked, cab worked, I'm not sure if the electric fuel pump was running. It was 1 of the 2 relays behind the batteries. Can't remember if it was the top or bottom. Then again yours could be something totally different. Check to make sure the electric fuel pump is running, connection coulda' came loose.
