stonerock
the little hyd cylinder for the belt tenisoner is leaking oil it came apart. how do you put this back together? and or how do you take it off
3hrs later got the cyl off. it blowed the seal out the end of the drum.took it apart scored on the inside, rebuild kit 100.00 or new cyl 310.00. got a new cyl comming tomorrow morning. i bet it dont take that long to put it back to gether.
Looks like there's probably a snap ring on the inner end of the rod that would be accesses through the hydraulic line fitting.
NOT sure what you mean about taking it off, as it's just held on by a couple of pins (and the hyd hose).
<img src = "http://jdpc.deere.com/pimages/HP23/HP2377_________UN01JAN94.gif">
