Good day to everyone. Took my JD 6620 out for a trial run on my beans. It looks to me that I am losing a good number of beans out of the back of the combine. I have set the combine up using the spec's that are in the operators manual. The beans in the tank look good and clean with a few pods that suspect I caused when I left the thresher engaged with the engine idling.
I am not sure if my fan speed is to high or if I need to adjust some other settings. I used this combine on corn last year with good results.
This is my first year with beans and I need to learn a lot about harvesting them.
If you can offer some advice on adjusting my machine I will be appreciative.
