young tractor
Hi guys,
I am new to my JD 4400 combine. I am having trouble with my auto header height control. Earlier this fall when greasing and setting up my combine everything worked fine. Now in the field the head won't automatically lower when you get it close to the ground. It does raise like it is supposed to when following the contour of the ground. But then I need to manually lower it. I cleaned the terminals, but didn't help. Can you help me trouble shoot this problem. Thanks for your help.
