Getting my Gleaner ready for harvest.
This will be my first year with this combine. It is a 1977 Gleaner K2. I'll be harvesting soybeans with it. It has a 12' head with a HC floating cutter bar. This past weekend I worked in the cylinder area. The cylinder clearance gauge was way off. Gauge showed 1/4" and it was at least double that. I zeroed it out and reset the gauge. I then opened it up to 1/2" clearance. Previously it had concave bars in the 1-2-3-4 positions. I changed it to have bars in the 1-3-5 positions. What do you guys think about these settings to get started?
I have a 1973 K and cut 10 acres of beans on Saturday before the monsoons returned. My machine has same as new cylinder bars and I ended up with my settings as follows: cylinder clearance at 3/4", concave bars at 1,3,and 5, cylinder speed as slow as it will go on 13" pulley, air as fast as it will go, chaffer at 9/16, and sieve at 7/16. Moisture range of 14.2 to 12.8 depending on where I was at in the field. Your settings may be different on the air as I am not sure if the K2 had two cleaning fans and your chaffer and sieve are longer giving you more cleaning surface. Good Luck
that is the exact setting I ran with my K2, I did have trimpe bars in it though. k2 was a good running machine.
Wow, depends on the bean moisture, I was running at 1/4 inch in beans at 11-13%, very few cracks. But that is on F and M series.
I'm just a tad over 1/2 inch on corn now, getting mostly full cobs out the back in 21-23% corn.
Paul
Always a good thing to zero the gauges on a new machine. I typically use the same spacing on concave bars. Make sure the unused spots have bolts in the holes so beans don"t escape.
When I had a FCB I put a rod on the thresher housing, coming up in front of the cab window (in a ring mounted to the bottom of the cab). Painted the end yellow, put black tape on the window at top and bottom of FCB range, so I could see the yellow mark when dust was too thick to see the FCB.
