rustyacres sd
My computer was with the IT dept to be worked on. He crashed the Hard drive, so I am starting from Scratch. Since I had time off, got some work done around the acreage. Got the big girl out. the 966 and did some chisel work. Got the little girl out. 135 mf and worked up some of the garden. Decided to work on the K's. Got the K with the 330 corn head running. Then worked on the K with the 13' straight head. Took a little more and got it running. Need to adjust timing, because when I shut it down it likes to keep running, and hand to choke it to get it to die down. With all that done, decided to see if the 4 wheeler wanted to run, and by golly got it to go. So all in all, all engines where running on Saturday.
