perferated door on clean grain clean out
Did you try A and I? They seem to have every other part for IH Rotor Combines.
I do know the 20 series parts are a little harder to come by.
Found it below.
Gary
Its here.
The Case/IH PART # for perforated door for clean grain elevator is 186309C1 and looks as still available in the $60+ price range. If A&I offers it they would probably just put an A in front as they did on tailings door. So you might call them and ask for A-186309C1. If they don't there are other aftermarket companys that may.
After posting I thought maybe I could check if A&I had it by using Gary's link (thanks Gary) . I got connected and appears A&I does not offer it. I checked Shoup Mfg with no luck also.
Buy the OEM ? Or if more than you want to spend maybe they would know of alternative.
