FordTractorMan
Last time posted here, I was getting the M2 ready for wheat. Didn't go well. Managed to cut 2 acres of wheat. While I was doing that, the belt that drives the head auger came off twice - 2 belts actually - outside one would jump off and the inner one would jump onto the outside groove of the drive pulley and stay on the inner groove of the auger driven pulley (that make sense?) It never would cut/feed right, and when the sickle bolt fell out of the wobble box (replaced it), I found out why. All 4 bolts that hold the wobble box on were loose and all the holes were elongated. Tightened them, but only lasted about 15 min. before loosening again. Plus, I managed to choke it twice. The engine seemed to pull down more that it should and I wasn't even in heavy weeds when it choked, just a small patch of horseweeds a few inches taller than the wheat, and not a solid patch. You could see wheat between the weeds. Machine is a spike tooth at that. Going to try my luck w/corn. Head is on, all chains oiled. Going to grease it and hope I can slow the cylinder down enough that I don't grind too badly. Heard mixed reviews on spike tooth in corn. Planning to change fuel filter, too. Hoping to have better luck in corn, but E3 is on standby. It got the wheat.
