3rd owner CASE 600
Case Nutty 1660
Thought you might like to see the newest addition to my CASE combine fleet, a very nice 1965 "600" 10' head, header control, Innes chopper and special cup clean grain elevator, and 188 CASE gas engine, even has the full set of goodies that came in the tool box new, most has never been used, last shot is her arriving via a "Hot Shot" ride here from MI
cnt
Does that have the slant 6 engine? BIL had a 600 with the slant 6; he said that it was underpowered. We had an 800 with a Case engine. After I got the engine up to the RPM's it was supposed to operate at, that was a good combine.
I made a mistake on the year of this "600" it is a late 1963 model not a 1965. I got her all put together today, need to wash of a couple things and do a service then she can wait till the alfalfa seed crop is ready, may get to run her a bit yet this year, the last pic shows the largest and the smallest of this series machines, 20' and 10'
Very NICE!. My neighbour parted his 600 Combine out ten years ago and installed the 188 Engine (gas)into a case 610B tractor. I purchased it.....lots of power. Great Utility Tractor....Case - o - matic. Also installed the CASE 600 Combine driving rims and tires so as to lower the Tractor profile.
Bob...
casenutty you have to be the luckiest case guy on the planet. That combine looks like it would clean up real nice. Must be a very low hour machine
Where or how do you find these gems?
Case Nutty,
Sorry to ask as it's probably been listed before but my search turned up nothing.
What are the specs on a 660? Height, Weight, width of front tires, and anything else you think I should know to trailer one. I found a nice 1969 660 with a 14 ft bean head not far from me, but it's too far to road it, and I have wanted one of these for a long time.
my 660 ops only gives wheel base and tread width,
wheel base length 120"
width drive tires 79-3/4"
height with out cab and screens folded is right at 10' depending on tires with cab add aprox 2' my 660 with 18.4 x 26 rice tires stands taller than my 1660 but the 660 has two bin extensions which is higher than the cab, I can measure mine to get a accurate height if you like, the machine should be 16' or so long with out header again I can get you closer specs, weight is 7050 with 12' header and no cab, header weighs aprox 1200lbs depending on size, your 14' 1300lbs I would guess would be real close
