Dave from MN
IaGary, I emailed you on this also. My recently purchased 1460 has the large wire concaves in, and the fron two both have every other wire removed. I was planning on using only for beans this year, but possible corn with a 6RN head if the 1420, or mother nature give me a reason. Can I combine beans OK with these wires removed? How hard is it to remove the concaves and replace the wires( of which I do not have) or just a different set of concaves? I also see there is a cover plate available too, but I read that the concaves need to be removed to attach some hardware the first time you install them. Combine has been at shop longer than expected and I wantt o get it ready fo rbeans which at maturing fast here since the freeze. Any advice will be helpfull, benas will bushel anywhere from 20-close to 50 in the heavier soils.
