New to MF combines, just recieved a 550 - good overall condition, with 13ft grain head, wide concave spacing. Handbook says concave at front should be 8mm when adjusting lever is at notch setting 5, 1.5mm when at notch setting 1 and 32 mm when at notch setting 11 (full open). I tried to measure clearance between rasp bar and concave front bar through the little access window on RHS, clearance (at notch setting 5) was almost 3/4" - I adjusted the long concave rod full in and full out, when full in, the concave clearance lever wouldn't close any more than notch setting 3, when adjusting the rod full open, the concave clearance lever wouldn't exceed notch setting 8 - yet I can't see the drum hitting the concave anywhere - Im pulling my hair out, need to cut Rye (front setting 5mm read 3mm), from what I can see, I have no chance of getting those measurements - what am I missing here ? Thanks
Tweedler
Tweedler
