JD 213 head adjustments
super99
I have a 213 head on a 6600 with 18.4 tires. When the head is lowered to float position, the sickle is 3 or 4 inches from the ground. Is this normal, or are there adjustments to change the pitch of the sickle?? Thanks, Chris
I have a 6600 with 215 but it is a flex head with it in 0 on header height control it goes all the way to the ground....not sure if it helps but that's what I know...hope harvest goes well for ya
I should have said that when the head is lowered all the way to the ground, the cutter bar is still 3 or 4 inches off the ground. It is a flex head without header control.
