Dave H (MI)
Hope I haven't asked this before. I have all the lights on the combine working EXCEPT the last three lights on the "worklight" circuit.
1)lamps test good...all will light if powered.
2)connections on the three lights read no power on VOM.
3) Power connections on the three lights read no power when put to an independent ground.
4) When a hot lead is connected to VOM and then to the ground for the three light it does not read.
If you follow the above, there is clearly a break in both wires to these last three lights. They are inside the loom and not visible. Does anyone know if these last three lights are wired in line with the previous ones (so the break would be between the last working light and the non-working lights) or does the wire for the last three go further back (hopeless to find).
I would be able to fix all this if I was not running blind. I need a wiring schematic for the light circuit. I have not been able to find one on line or a service manual for that matter. Does anyone have a schematic?
