Zach Scherf
Working on a 1460, the owner hit a telephone pole with the augur and bent the swing cylinder. I switched out the swing cylinder and tried it with the cylinder not attached to the augur, it didnt move. I unhooked the hoses to the cylinder and moved the lever in the cab. Still nothing. I pressure washed outside of the machine and traced the lines back from the bin to the valve body outside the cab door. The valve body runs the augur swing and the reel height. There is no head attached. This valve body is not getting pressure I don"t think I already checked the fluid level and am confused. Any ideas
