Dave H (MI)
I'll keep asking them and hope someone knows. Which lights are the "headlamps"? I pretty much guess that it is some combination of the four lights above the windshield but probably not the two on either side that point at the header. Do all four operate as headlamps?
In checking continuity on the harness I need to know what lamps should be getting power in each switch position. The manual tells you, but does not say which lamps are which. I am looking for HEADLAMPS. Which are these?
