Dave H (MI)
Anyone familiar with the front work lights on this type of combine (1600 series, may be the same on 1400's I don't know)?
I have tested all lights by running power to them directly off a 12v power supply. They all work individually. I have an issue with the two left most lights (there are four mounted above the windshield). These two lights are loose and need to be tightened to the combine. The threaded stud on the light goes into the header above the windshield. I see no way to get to the back side of this to tighten the light down. The nut on the outside does not turn. This was a problem for the PO because he used a bungie to hold the two lights together. Can someone tell me how to get to the back side of this? I have the roof off and it is not in there. Any help appreciated.
