9760 fuel gauge
Mike Bock
got a 9760 the fuel gauge shows full all the time even when sending unit is disconnected also fan speed will not speed up only will slow down checked relays and fuses etc. the motor will work if hook up with jumper wires
You have CAN Bus issues. It could be a lot of things but I would believe it would be the corner post circuit board. That is a very common problem on them.
