So i"m trying to adjust the pto on my buddy"s Case 430. It has the lever that you reach behind you and operate with your right hand from the seat. I have removed the pipe plug directly above the pto itself and I cannot find any spring pins to push in. The only thing i can feel is each bump of each ball/roller bearing. If i go on top of the outer collar, i cant even get anything in there without engaging the pto, and then still can feel anything (although with the angle im at, could be missing).
I"ve seen the parts breakdowns a few times and i cant find the pin on their either.
