You had questions about wiring an older Gleaner for a flex head. I"m back from Alaska and can give you part numbers for the module and the harness that you need. The harness is 71317454. The module is 71345087. They are found on F3,M3,L3, and some N series machines. A Gleaner dealer can check out the module, also Ag Express in Des Moines (515-289-2746) as well as MCC Electronics (816-795-0600) (near Gleaner factory in MO?)
For the M2 there is a serial number break...23801 (1982) and up. 6 pin disconnect. Module has 2- 3 pin disconnects and 1- 6 pin disconnect. 3 position rotary switch...Low-Medium-High.
I have dealer printed material re diagrams, etc. that I can send...email is open
